rb25drag wrote:Your wasting your time with that puller, If im not mistakin I have one just like it I tried but nothing worked right.
Im with Shocker, I bought mine from AutoZone, Get the Biggest 3 jaw you can find, I had to take mine and make it a 2 jaw( it will Convert), But it will pull it off. I have used it many times.
Also as Matt said Put the Center bolt back in ( only about half way) to use as foundation you push against, If you notice in the end of the bolt it will have a groove in it were it has been Center drilled specific for this reason.
I use that puller and my time was not wasted. :P
it works if you know what you're doing and you won't risk ****ing up your balancer.
Like someone said, there are 2 tapped holes. Just pick up some 10mm x 1.5 (60mm length should be long enough) metric bolts and washer from Home Depot. Cost of cents vs your balancer getting cracked.
