Crank pulley part number
captainfalco
Car: S14,MX83
I found the part # for the s13sr, but not for the s14/s15sr. Are they the same? Any Ideas?
captainfalco
Car: S14,MX83
bump
captainfalco
Car: S14,MX83
someone's gotta know this
duffman1278
Car: 89 240sx Hatch, the wildcats!
Search in the Sticky for F.A.Q. there should be a section for part numbers. I'm going to try and look it up on FAST, but search there meantime.
duffman1278
This is all I could find
captainfalco
Car: S14,MX83
thanks a bunch! I did look all over the stickies and all I could find was the s13 sr #.
SpeedRacer1
Car: 1990 240SX, G35
S13 part number 12303-52F00S14 part number 12303-65F00
The S14 pulley is different because the ps belt is thinner. This is why they arent entirely interchangable. You can swap between the two and just use the thinner ps belt though.
captainfalco
Car: S14,MX83
So all I will need to use is the S13 power steering belt then, or trim a rib or something off of the S14 belt?
