Crank pulley nut size
SR20Essex
Car: 1989 Nissan 240SX, 2007 Infiniti G35 Coupe
I was just wondering if someone knew what the Crank Pulley Nut size is (SR20det). I know its smaller than 30mm and larger than 26mm (I have those sizes). I just don't want to buy 27-29mm just to cover the right size because those large single sockets are friggin expensive. -Thanks
Hijacker
Car: '92 240sx Convertible
'94 F-150
i've always used standard sizes since that's what's lying around that large (metric for anything 18mm and under) Anyways 1 and 1/16 is the size. which is a 28mm IIRC.
Slipstream
Car: '94 Sonoma, '90 300zx n/a
I used a 1 1/16th socket (same as the oil pressure sensor) to turn mine.
vutony
Slipstream wrote:I used a 1 1/16th socket (same as the oil pressure sensor) to turn mine.
yup, its 1 1/16th, been using all week
Hijacker
'94 F-150
vutony wrote:yup, its 1 1/16th, been using all week
Bah, you guys are right. I can't remember my SAE sizes to save my life. Changed what I said earlier so not to screw anything up.
180fan
Car: 89 fastback
27mm
ILikeMy240sx
Car: SR Power
what he said... 27mm
SR20Essex
Thanks, 27mm is right, 28mm is loose. I just stopped being a tightwad, went out got a compressor, a large set of metric sockets and some air tools (one with 500ft/tq ) and I'm going to do it up right. I work on this thing enough for those air tools to save me some serious time.
Thanks again for the help
