Crank Pulley Install??
72nismo
Car: 510 / G35 / Murano
When installing new crank pulley is it suppose to slip back on or am I suppose to tap it in with a rubber mallet??
BMAR240SX
Car: 1993 Nissan 240S Coupe
Is it an aftermarket
72nismo
Yes. Bought From ebay.
BMAR240SX
Do you have the right belts that are recommended to fit the new pulley... if so its gonna be tight i would play around with it trying to get it in before hitting it
BMAR240SX
which ebay pulley pulley did you buy...how much did you pay and can you give me some feedback if you get it installed maybe some pics..goodluck
180fan
Car: 89 fastback
It should go on with motivation. ie you might be in for tapping it in with help from a rubber mallet but it should not just slide on all the way with ease. It should be a tight fit on the crank but not so tight that it'll score or seize on the crank.
BMAR240SX
Hey man how did the pulley install go...was it worth it im interested
72nismo
I havent done it yet. I woill let you know when I do it.
