Shift__BODOM »
https://forums.nicoclub.com/shift-bodom-u20648.html
Wed Dec 22, 2004 9:50 am
put it in 5th, engage the e-brake, and get either a breaker bar (autozone or o'reily), or a long hollow pipe thats wide enough to fit over the handle of the ratchet. the longer the better, also, hold the bar at the highest point that you can. the higher you hold it, the more leverage you have over the bolt. my can was totally jacked up (4 stands + garage jack) when i was doing it, and i had no problems whatsoever. just brace yourself against the bumper, and put all your weight into it. also, the pulley will turn about 1/16th of a turn at first, but don't worry, it'll catch, as long as it's in 5th. you should be glad you dont have a mustang though, my friend and i were doing an underdrive pulley job and we had to use 2 pairs of vice grips on the harmonic balancer and wedge them up against some bolts that were on the block. took us 10 hours to figure that out lol.
anyway enough of that, have fun with the job!
