Crank Pulley Bolt
fuzzy_tanit
Hey guys, I have an RB26 and I'm trying to get the crank pully bolt off. I've tried heating it up and penetrating oil. My air gun wiil not pull it off and it's good for 1,000 ft pounds of torque. Any suggestions would be helpful.
minivan_don
you need to stop the engine from turning it over. if you still have the flywheel on, then you can use a socket to stop it from turning it over.
SR20COUPE
sorry for the different username at the top but I was at a buddy's computer and he was already logged on. I've got it were the crank does not move and the bolt still does not want to come off. I'm gonna try and take it to my friend's shop and heat it up with a hotter torch. My friend said that is what they do when they pull the bolts off the 2JZGTE"s they work on. Personally I did not want to take the motor out of the garage.
Bluefire
I believe the bolts is torqued to like 300 ftlbs or something. You need to secure the motor, and make sure it doesnt turn over. You should be able to use a long breaker bar to loosen it. Also its a bit hard to use a torch since you want to heat the material around the bolt not the bolt itself.
SR20COUPE
I got the bolt out I had to use the torch off the welder.
RB_Dreamin
hope you didnt warp the crank
240z4u
Car: '95 Nissan 240SX
Does your impact say its a 1000ft/lb gun? Or is it a 1000 ft/lb gun?
Sounds like you need to borrow a better gun from one of your buddies (then you would not have to take it out of the garage.)
BTW, I pulled mine off with a huge (3 ft) breaker bar and a socket. I used a good quaity ratchet and a long jack handle.
Good Luck - Evan
Darius
Car: RB25DET S14 - 665 WHP (SOLD)
My impact wrench doesn't work as well as me with a 2 lb sledge and a 1/2" drive socket wrench. Just get your buddy to hold the socket on the crank when you wail away on the wrench.
Squirt the back of the crank pulley with penetrating oil too because if your nut is rusted in there, your pulley is probably corroded to the shaft too.
SR20COUPE
My gun is a MAC TOOLS gun and it is a 1,000ft/lb gun. I don't know for some reason it didn't do the trick. The welder did not get the bolt hot enough to warp the crank. I appreciate everyone's help.
Shocker
Car: 89 240sxHB rb26/30
Ok.. I just did this tonight... Install one flywheel bolt, get something long and skinny that will become pressed betweem the flywheel bolt and the engine stand and act as a brace so the rotating assembly doesnt move.. get a breaker bar on there with an impact 27mm socket, then get a ***** bar and slip that over the breakerbar... make sure w/e way you are rotating make it so you can use your body weight... and there you go... pulley bolt off.
Sil240
Car: Nissan S13 "The One Cam Wonder"
Why are you heating up the bolt????You are making it worse.
Your suppose to heat up around a bolt, not heat the bolt itself.
Heat makes things expand.What you want to do is make the outside expand, so you can hit the bolt with the gun.A little MAP gas torch should be more than enough.
Darius
He can't really get at the crank if the pulley is still on.
Sil240
Hey,If the motors in the car put the car in 5th gear and have someone step on the pedal.
By the way.What size is the crank pully bolt??I'm not sure if I have it or not.I'm pulling mine this weekend and want to pick one up tonight.
fly240
Car: nissan 240sx
hey, i was having problem taking out the crank pulley, i got the bolt out, but the pulley is so hard, how did you get it out...?.
gawdzilla
Car: none
pulley puller. the 26 crank pulley has holes for bolts to pull on, so get the 2 prong puller that pulls on the bolts.
lilskyline240
Car: 90 240sx w/ rb30det
ive found that an impact wrench for some reason sucks at taking out the crank pulley bolt. There is nothing better than good old fashion 5ft breaker bar
Coolwhip
Vendor
Car: RB26 Raw Brokerage War Machine
alittle FYI here...
The BEST solution IF the motor is in the car is...
Socket with braker bar wedged agaisnt the floor or something hard, and then blimp the engine on but don't start it! The starter has more torque than you think and can break loose bolts without a problem.
On the impact gun talk, i believe they rate the gun's ft/lbs on foward tightening strength not reverse (which is lower). make sure you have oil in your air tools as well and your compressor is up to the task.
Anyways, motor out, best way has been covered, old fashion with the breaker bar.
S13 240SX
Car: 93 Mazda Miata
has anyone mention to the thread strater to just put the damn car in 5th gear and then turn it and then bam it comes loosen..
OpeLok
Coolwhip wrote:alittle FYI here...
yeah I've done this many a times at work to get stubborn toyota crank bolts out. Another way if they motor is out is a chain wrench to hold the pulley, while you break the crank bolt loose.
Coolwhip
Vendor
motor was out of the car. And i believe he got the bolt loose. yes someone suggested the 5th gear tactic however the starter use is the ****.
KlanjacOFF
Car: Nissan 240SX
Yea, so I'm about to do this and my question is, should I worry about the flywheel bolt snapping in half and getting stuck in my crank? My flywheel is off the engine so there is some space between the bolt and the crank. Don't know if I should be worried about it or not.
BoostFab
Car: S13cp, S13fb, S14z
if you dont have air tools, i suggest you to lock down the flywhele so it wouldnt turn, then use a long breaker bar, and a metal pole, slide the pole over the breaker bar, that will break it loose.
KlanjacOFF
Car: Nissan 240SX
But the question is will the flywheel bolt hold up to it without snapping?
BoostFab
should be fine, slide in a long pry bar between two flywheel bolts to brace it
Modified by BoostsFed at 4:31 PM 1/9/2008
Darius
That is also what I had to do in order to get my flywheel bolts off. My crank bolt came off easy but that is an RB25 and the torque specs are way different. If you can do it, try not to mess up the threads on the lower half of the flywheel bolts so you can reuse them.
