Hijacker »
https://forums.nicoclub.com/hijacker-u9394.html
Sat Jun 19, 2004 9:41 pm
this is easier than the way daedalus posted.
if you have the car on a lift, you will need a friend for this. put the transmission in 4th gear (i've found that 5th gear allows for more slippage than 4th) and have your friend stand on the brakes while you tighten the bolt down.
If the car is on stands, make sure the rear wheels are touching the ground, place the car in 4th again and then set the e-brake very hard. The weight of the car and the torque needed to even move the car forward should keep you from accidentally pushing the car forward.
Also, if you ever have to get it off again, this is the best way, ie by having someone stand on the brake while the car is in 4th.
