sandcrabsailor »
https://forums.nicoclub.com/sandcrabsailor-u142566.html
Sat Oct 16, 2010 2:51 am
It is recommended for high-revving engine, and you can tell a difference when you drive a car that is balanced, and one that isn't. Throttle response is immediate, and the RPM's are smooth and quick. It doesn't stay in gear long, goes right through them, and when you get into it, it goes.
If you got the chance to do it, get it done. The car is so much better.
Whether or not you get a new crank doesn't have anything to do with the need for balancing. If you change the pistons or rods, then the stock balance job is no longer valid. You can have it balanced with the stock or aftermarket crank.
Balancing an engine will not make more power or give it more response. Balancing is mainly a reliability step that will make bearings and the crank last longer. The higher you rev the engine, the more critical the balance is.
(blatantly plagerized from LS1tech forums)
