jynxtrix »
https://forums.nicoclub.com/jynxtrix-u85010.html
Mon Aug 17, 2009 4:42 pm
right, so I never figured out exactly what was causing the noise, but I did figure out how to stop it. When I first started my project it wouldn't run without the valve cover plugged. Well, i piped it into my intake like I saw in all the diagrams and it ran fine. Then I plugged it, and it ran fine, but that's when the strange noise started, I just never connected the two. Well, anyway, I unplugged it, and now it's pretty much just vented to the atmosphere. But the noise is stopped. It's running reasonably well. But I've developed a few other issues that I'm looking at. My idle adjustment doesn't really make a difference. I've torn it apart and cleaned it 3 times, but it just doesn't do crap. I have to adjust my idle with the screw that is on the throttle body, and I don't think that is how that is supposed to work, lol.
And then there is the boost cut. or speed, or what ever. I just know that no matter what gear I'm in, it cuts out at the same speed. I'm still working on that. Could it have anything to do with my lack of correct transmission wiring maybe? My 5th gear sensor isn't hooked up, but should that matter. Oh well. Shoot me full of wisdom if you got it. If not, Just Shoot me.
