Vehicle was then brought to another shop, who did nothing but at least did not charge them. Owner gave up and sold the Rogue to me as-is sight unseen (I work with the owner so I was aware of the whole situation but had never seen the car.)
I towed the vehicle for about 5 miles on all four wheels using the tow hook (25 mph or less.) One tire was almost flat upon pickup.
Since obtaining the vehicle I have cleaned it, drained and replaced the fuel, filled the tires to specs, replaced the corroded battery, rechecked every fuse, checked the ECM relay, and removed and re-installed the ECM, BCM, and NATS/IMMU unit on the ignition switch (took photos for future reference of codes and part numbers.) Vehicle still cranks no start. Several lights on dash.
Another noteworthy item is the brake pads/rotors were never changed in 71,000 miles.
I have attached a like to a video of the starting sequence for review. Any suggestions would be most appreciated. I like this car and intend to do all the other needed maintenance one it actually starts.
[youtube][/YTXBYiYZtCg]
