Crank/No Start
All things Altima Coupe.
stevewaclo
Car: '08 Altima Coupe SE 6sp 105k
Hello,
Clutch in, push start and engine cranks (until time out) but no start.
Seldom has to crank for more than a second or two when OK, so the cranking sounds are new to me.
Sounds somewhat labored with perhaps an occasional start attempt.
Just gave it a shot of starter fluid and now it cranks much more briskly with what sounds like a random attempt to fire, but start sequence times out.
Battery was on charge overnight and load tested OK at O'Reileys this morning. Terminals and battery connections are clean.
Nothing in search.
At 105k, car has been a gem and this is my first issue of significance.
Help!! :ohno: :ohno: :ohno:
stevewaclo
Iridium plugs are original, but hard to believe they would all die together.
stevewaclo
OK,really stumped. Picked up an iridium plug and had the wife hit start.
Good spark on the COP I pulled.
Two guys at different parts stores suggested crankshaft position sensor.
Hate to throw parts at it w/o a diagnosis.
stevewaclo
stevewaclo
Easiest fix ever!
Sensor is straight up, while on your back, about 1' back from front of car on the bottom of the bell housing.
$60 part.
What was odd was I was throwing big sparks and ether did not help. :wtf2:
Oh well. All is well :bigthumb: .
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2022 Honda Pilot SE
2025 Honda CR-V Sport L
Duplicate thread deleted.
Cross-posting (i.e. posting the same topic in more than one forum board) is frowned upon. It's confusing, counterproductive, and unnecessary. Please choose the forum area that is closest to your topic, and place it there only. If you should create a topic in one forum, and later realize it would be more appropriate in another forum, please delete the original before posting it again.
stevewaclo
