Crank no start.. ECU??
DubsSuck
Car: s13 hatch
ok heres whats up, my KA24DE won't start..
things i did:checked fuses and relays. Goodfuel pump. goodignition coil. goodignition switch. swaped
heres whats happening. when i put the key in the ignition and turn it to 1 the the engine/ECU light comes on dimly. when i turn the car to Acc the light goes off and the break light comes on. for some resone when i try to turn the car over power isn't being sent to the ECU, end result.. fule pump doesn't prime and the coil doesn't shoot a spark.We looked up where the wire was that fed power to the ecu and it had some resistance. so the power feed is fine.. Im clueless! help!
zach-Ka
Car: 1990 240sx (SR)
Check the voltage at the (black/white) and (red) wire where your harness plugs into the two brown and grey plugs behind your passenger side headlight. Those are you ecu main and back up power.... Maybe you have a short in them....
DubsSuck
Car: s13 hatch
ok i checked the resistance on all of the plugs and they seemed to be fine..
but earlier today i was just playing around with the ecu and i got it to shoot a different (different than 34 knock sencer) code and when i tried to crank it there was combustion.. but not a complete turn overthe code was a strobe like flash. 1sec strobe. then a big long one that lasted about 1 or 2 seconds. after that it didn't give any more codes.. right now its on the battery charger
grr its been since july... i need to drive it
DubsSuck
Car: s13 hatch
oh god i needed voltage not resistance..
zach-Ka
So you do or dont have good voltage coming out of those wires?
DubsSuck
Car: s13 hatch
yeah the voltage is fine we got the ecu to work correctly so thats not the problem..
but we did a compression test, something we should have done to start with. but one and two were.. i think 110 and three and four were 95. so my question is.. is there any way to ajust the values with out taking the head out?its not rings cause we put a few drops of oil in it and the compression didn't go up..so yeah help pleas
DubsSuck
Car: s13 hatch
but that still doesn't explain why theres no boom... it should still fire with low compression right?
zach-Ka
Your coil is getting the right amount of volts? Is you battery ok?
DubsSuck
Car: s13 hatch
yeah the battery is fine what is the right amount of volts for a coil
zach-Ka
12v
DubsSuck
Car: s13 hatch
theres something wrong with that picture.. GOd im dumb
DubsSuck
Car: s13 hatch
RR240SX
If that intake cam is timed then that exhaust cam is about 160 degrees off. Pull that guide also.
DubsSuck
Car: s13 hatch
yeah i did that and then i took the vid and it turned over... but while trying to turn it over i fried the starter..
