jaworski88 wrote: ↑Fri Jul 23, 2021 10:48 am
My thoughts/questions: These are long shots... but maybe the antiseize had something to do with it, perhaps too much on it???
Copper anti-seize
would not prevent the spark plugs from firing, but can cause other problems, it's good you took it off. From the NGK website:
NGK spark plugs feature trivalent plating. This silver or chrome-colored finish on the threads is designed to provide corrosion resistance against moisture and chemicals. The coating also acts as a release agent during spark plug removal. NGK spark plugs are installed at the factory dry, without lubrication or anti-seize.
Anti-seize can act as a lubricant, altering torque values up to 20 percent, increasing the risk of spark plug thread breakage and/or metal shell stretch. Thread breakage can sometimes involve removing the cylinder head for repair. Metal shell stretch changes the heat rating of the spark plug and can result in serious engine damage caused by pre-ignition. Do not use anti-seize or lubricant on NGK spark plugs. It is completely unnecessary and can be detrimental.
