Crank like 12 times before starting
AKC_Samurai
Car: 1993 240sx coupe
Hi all,
My car is acting funny again... since yesterday, it takes quite awhile to start the car. It cranks, but it would not start till 5 seconds later.
The day before only took 1 crank to start, which is weird too. Usually it takes about 3 crank to start.
I've replaced the battery, cap and rotor, and spark plugs last week.
Any idea guys?
Thanks!
Chaluska
did this start happening after you did the tune up or before?
AKC_Samurai
It starts after the tune up. But since then it has been a week. I also replaced one of the injectors.
By the way, it is a ka24de
corn322
Car: 1993 240sx
Did the lower O-ring for the injector tear when you put it back in? That will make it hard to start.
AKC_Samurai
corn322 wrote:Did the lower O-ring for the injector tear when you put it back in? That will make it hard to start.
i'm not sure about that actually cause my friend put that in. I just realize my car will start right up when the engine is warm... :rolleyes:
