Crank C- Number 1 cylinder lost compression, seller bought a new motor...says crank is good
thats what I would get, assuming the 0 compression was due to rings blowing out so that crank is still "good"
The others would need to be machined again thus $$
You could also consider getting a spool imports stroker crank, only 1700 AUS. NEW!
