yes crank will be rebalanced once the crank collar is on (btw, the guy who was selling 1 turned out to be a fag and refunded my money at my loss).
ive already ordered an n1 oil and water pump, timing belt idler + tensioner. im working on getting the PE timing belt and tomei oil orifice. i may hold off on installing the orifice as im not sure if im going to pull the head just yet. ive also got a FULL oem gasket kit and arp head studs chilling out under my bed - just in case. i didnt plan to replace the rod/main bearing or rod bolts if im planning to reuse the stock rods/pistons.
what i meant what else i should replace is like going with forged internals (if i happen to find an abundance of money in my bank) but if i did it would tempt me to go with a gt35 vs a gt3076 as well as a few other parts all just more money right...
i found this:
http://cgi.ebay.com/ebaymotors...ZWDVW
from my dirt bike experience, im not a huge fan of weisco pistons (aka SEIZE-CO!!) for that reason. id also have to account for all the machining but everyone and their grandmother would say its a good idea while you got the engine out. ive also found crower rods and cp or je pistons. rod/main bearings are like $300 US and arp main studs $ ??? = LOTS!!!
