AustinSilvia »
https://forums.nicoclub.com/austinsilvia-u13268.html
Sun Dec 05, 2004 7:57 am
posted on another ka forum but want as many replies as i can get...
so i have my intake and exhaust manifolds off, installing fresh lines in many places and setting everything up for the turbo with oil feed and return and what not. when i took off the upper intake manifold i noticed a very small amount of oil sitting around where the crank case ventilation comes into the runners just before the head. the odd thing is that the ka has crank case ventilation coming to all 4 cylinders instead of just one. this makes me think that they want a little oil to get through and lube the intake area (valves and what not), but i have no idea. is that oil supposed to be there? i'm going to do a compression test again once it's all back together, but right now i'm kind of worried i have bad compresion and oil and sludge is getting blown up into the manifold as a result. someone tell me what's going on.
if i do have bad compression, well then i guess i'm just that much closer to getting an sr, but i really dont think that is the case. my ka pulls as strong or stronger than any one i've seen in stock configuration. i have a '92 with a supposedly rebuilt (not 100% sure but it runs like new) '95 engine, and i beat my friends '98 in a straight line race (and he has exhaust and other things done to add a little more power while i have everything stock).
