Mettler »
https://forums.nicoclub.com/mettler-u36299.html
Wed Jun 06, 2007 3:13 pm
Hey do you guys see any problems with the following?
Directing the crankcase ventilation at the back of the block directly to an oil catch can, and plugging up all but one hole on each rocker cover, running further lines to the catch can from these two holes.
The crankcase can already vent up to the rocker covers through the oil drain holes in the block & heads, and I can't see that enough pressure would build up to require all these additional breather hoses.
I figure running the bare minimum to the catch can and plugging up the rest should be fine. It'll certainly help with reducing the clutter under the manifold.
