Crank Case Pressure and General Running Issues After Resetting Cams
float_6969
IDK if you guys have tried this, but I get 2 vice grips and when I get the marks on the belt lined up with the marks on the gears, I clamp the belt to the gears with the vice grips.
Buddyworm
float_6969 wrote:IDK if you guys have tried this, but I get 2 vice grips and when I get the marks on the belt lined up with the marks on the gears, I clamp the belt to the gears with the vice grips.
Werd, I use those big black paperclip thingies.
meminto
Car: S13 Silvia CA18DECT
Yep butterfly clips FTW!!
bentvalves
Car: 89 Silvia K's
when I get the gears lined up where I want them I stuff a screwdriver behind the gear in front of the backing plate.
wedge those f8ckers in place, then proceed.
