Crank Case leaking, Doesn't hold pressure. Help!
E10
Car: s13 240sx coupe
While trying to figure out why engine wouldn't start, realized there was no vacuum by placing hand over throttle hooked up a gauge and it didn't even move. Used compressor with remaining air left in tank to do a leak down test in cylinder #1 at TDC and expected engine to turn a little by the pressure. Air doesn't leak at intake/exhaust, sounds like its coming from the crankcase.
My thoughts either a hole in piston or worn out and need to get bored etc.
When I got the engine it was off timing, could that have caused a hole? Engine hasn't started since I got it.
Thinking i'm going to be rebuilding my engine now correct?
90 compression all around when doing compression test if that matters
Lobo240sx
Car: 1991 Nissan 240sx Coupe SR2.35DET Redtop Build
Compression is too low. Should be 145psi and up. Time for new piston rings.
E10
Thats what i'm thinking.
