VStar650CL »
https://forums.nicoclub.com/vstar650cl-u299034.html
Sun Aug 20, 2023 7:08 pm
You have to be dealing with pinheads who can't read or don't care. The VG33 crankshaft sensor isn't used for any operational purpose. This is a direct quote from EC-277 in the FSM:
The sensor is not used to control the engine system. It is used only for the onboard diagnosis.
The main thing it provides is the tach signal, so if your tach works, there's nothing wrong with the CKP. Even if it didn't work, it wouldn't affect starting or operation in the slightest. The fact that it ran badly when the CKP was pulled meant absolutely zero, it was a coincidence.
It sounds to me like you need to go back to basics. Start with a scan so you know what the ECM is thinking, verify fuel by squirting some Brakleen or Gumout down the barrel, verify power and (especially) ground at the distributor, verify spark coming out of the distributor, verify spark timing with a light, pull the MAF connector and verify that isn't causing the problem, yank the front O2's to see if it starts without them (meaning your cats are clogged). Once you have a few things ruled out, you can start chasing whatever isn't.
