fiznat »
https://forums.nicoclub.com/fiznat-u1372.html
Tue Oct 12, 2004 9:45 pm
I'm in the process of putting all the wiring together for my KA(t) engine, and for some reason I'm having a lot of trouble finding the CAS (crank angle sensor: on the distribiuitor) wire + plug. The FSM says that the plug is right there along with all the other wires that go across the injectors/fuel rail (like the TPS/coolant temp/MAF/power steering pressure switch/etc etc etc), but I dont see it anywhere. What I do have, however, is one plug that doesnt match up to anything, that looks like it used to run across the top of the fan shroud... I'm thinking that maybe that plugged into a subharness that had the CAS plug on it.
Aaaannnyways, I was hoping someone could go out and take a quick look at their S13 engine, and follow the wire that plugs into the distribuitor: tell me where it goes and what it plugs into... number of pins in the plug etc etc... anything that might help me track this down.
Thanks guys!
