forecast »
https://forums.nicoclub.com/forecast-u7026.html
Sun Jun 29, 2003 7:29 am
... works in priciple just like a computer mouse.
To test it, pull it out but leave electrically connected. Turn the key to "on" and slowly turn the CAS rotor. You should hear the injecotrs clicking as the ECU activates them in turn.
Of course the ECU will complain if it thinks the CAS is broken, so this test is rarely necessary. If the ECU is complaining about the CAS, check all the wiring harnesses first, before replaceing it.
