crank angle sensor?
captainfalco
Car: S14,MX83
Does anyone know which crank angle sensor(the one in the bellhousing) I can use for my s14 sr20det? I have been offered a z32 one and a ka one but I am not sure if they would work. Any help would be very much appreciated.
ILikeMy240sx
Car: SR Power
Uhh... I dont think SRs come with crank angle sensors... I know KAs do near the back but never seen one on a SR
Hijacker
Car: '92 240sx Convertible
'94 F-150
SRs only come with a Cam Position Sensor (which is also called the Crank Angle Sensor by some) and bolts into the head. The only reference I can find to a Crank Angle Sensor in my KA service manual is to the Cam Position Sensor built into the distributor. The manual calls it by both names.
twofourzeroSX
Car: 91 sileighty
jeez its not a freakin maxima....
lol jk, but yeah theres only the CAS in the head
captainfalco
Car: S14,MX83
well, there is some hole in my bellhousing that i would some sort of sensor like that would be, i,ll try to post pics tomorrow.
Hijacker
'94 F-150
these are the only sensors in the trans. the only one not listed on that picture is the speed sensor, which is the tiny cylindrical thing directly below the neutral position switch.
the only other opening on the trans is in the bellhousing for the pivot fork.
Blown240sx
Car: 1996 240sx
LMAO
I love noobs
Its the speed sensor if it has a sprocket. And you need S13 for S13 and S14 for S14. If its a S15 motor then your ****ed unless you get a S15 rear diff.
twofourzeroSX
Car: 91 sileighty
not to thread jack, but what is the top position switch. i noticed that i could only name 3 on my trani the other day...this is the 4th.
captainfalco
Car: S14,MX83
It's definitly not the speed sensor, I know that. Actually it's right on the other side of the bellhousing, I can see the flywheel when the car is jacked up. It's a hole like 2-3 inches in diameter. And no it's not the starter either. I would imagine that it is some sort of sensor that drives off of the flywheel, but like I said, I will try to post up pictures later today.
captainfalco
Car: S14,MX83
twofourzeroSX
Car: 91 sileighty
ahh i thought u might be talking about that. you are missing a small metal plate that simply covers that hole. the only purpose for that hole is to remove those 2 nuts you see there. they are to the oil pan.
Seishuku
Car: 1987 Nissan S12, 5-speed, SR20DE+T 50trim T3@15PSI, Megasquirt 1 029y4
Those nuts, AND the torque converter bolts on the automatic model.
captainfalco
Car: S14,MX83
Ahh I see, thats a relief. I'll have to find someone to make a cover or something, I haven't a clue on how many of those are floatin around. Maybe I can snag one off of someone who is parting out their sr or something. Thanks a ton guys i couldnt find any info on that anywhere.
Blown240sx
Car: 1996 240sx
twofourzeroSX wrote:not to thread jack, but what is the top position switch. i noticed that i could only name 3 on my trani the other day...this is the 4th.
Im guessing top postion is the 5 gear sensor switch so the ECU can limit your speed.
ILikeMy240sx
Car: SR Power
twofourzeroSX wrote:ahh i thought u might be talking about that. you are missing a small metal plate that simply covers that hole. the only purpose for that hole is to remove those 2 nuts you see there. they are to the oil pan.
yeah what he said. Its a brozish looking plate that just goves over that hole.
