Crank Angle Sensor Situation
300zx1990ttjdm
Been having Starting problems after testing a bunch of things i pulled out CAS and and was gonna put in new one when i noticed that the notch inside hole where CAS is inserted is broken off am i screwed? isnt that what aligns the CAS? how would i fix that is that part of cam? or seprate piece?
mrmoose
Car: 91 300zxtt
you mean this?
http://www.jimwolftechnology.com/custom ... PartID=500
if so, no it can be replaced. also i have spare cans and cas if you are in need pm me...
300zx1990ttjdm
Wow awsome yah thats its been searching the internet for days so that little notch is required for proper alignment?
mrmoose
Car: 91 300zxtt
yes sir! although i have never had one replaced i hear they do tend to wear out. how you managed to break one is a great feat! congrats lol!
300zx1990ttjdm
no idea i just put this motor in my car and was all together ready to start but then it just wounldnt go checked injectors, PTU, spark and finnaly CAS and noticed that pin was broken.... s*** haha
mrmoose
Car: 91 300zxtt
its only the beginning! the zx is the high maintenance type of girl!
t.mcginley.jr
Car: 2002 Nissan Altima SE 3.5
1990 Nissan 300ZX NA 2+0
1966 Ford Mustang
mrmoose wrote:its only the beginning! the zx is the high maintenance type of girl!
Ask every Z32 owner how they know... haha
300zx1990ttjdm
what exactly needs to be taken apart to get that cam out and replace with another? how much do i have to take apart to get to it? any special procedures? is it just a remove and replace? never changed a cam before right now the motor is in the car with everything put together
mrmoose
Car: 91 300zxtt
pull plenum, timing belt, valve cover and cam caps. might as well do the timing belt while you are at it!
t.mcginley.jr
1966 Ford Mustang
mrmoose wrote:pull plenum, timing belt, valve cover and cam caps. might as well do the timing belt while you are at it!
plus the cam sprocket/gear ;)
