Crank angle sensor plug location on harness
wackawacka
Hi all,
Just bought an 01 xterra with manual trans.
A Crank angle sensor code was getting thrown so I checked the sensor. Nothing is plugged into it. I want to plug it back in but I cannot find the plug.
Does anyone know where the plug comes off the wire harness? Does it come off where the other trans sensor plugs are or does it come off the engine harness?
As you know this is a tight spot and I would like to have some idea what's going on before I start ripping the harness apart.
Thanks!
PapaSmurf2k3
Site Admin
I want to say it comes off the engine harness but I'm not 100% sure.
You might be able to find it in the factory service manual.
www.nicoclub.com/fsm
