I run an Autronic SMC on ca18det.
I also disassembled the CAS and installed the new trigger disc myself.
Autronic people don't predrill the lock pin hole, so you are left to do a hell of a lot of guessing where to put the disk once you've got the factory one out. My CAS came apart more than 10 times to get the position and orientation right.
The CA18 CAS disc is much harder to switch, when compared to the SR20 one.
EDIT:Appears you don't need a new trigger wheel.
http://www.hitman.hm/nissantrigger.htm
Ignition Setup Page 4-cylinder 6-cylinderTrigger Input Hall Effect Hall EffectTrigger Edge Rising RisingHome Input Hall Effect Hall EffectHome Edge Rising RisingTrigger Angle *45 *55Trigger Type Nissan NissanHome Window Teeth 16 24Nissan Tooth Offset *18 *5Spark Mode Direct Fire Direct FireCoils on 4-Cylinder 2 ---Engine Type Piston PistonOutput Type Constant Charge Constant ChargeCoil Charge Time (mS) 1.8 3.0Output Edge Falling Falling
Reference: RB engine forum:
http://forums.trinituner.com/f...04245
Modified by dattodude at 3:40 AM 9/10/2009
