need craigslist buying advice
elquinto
Car: '91 240sx
im looking for a sr20det. was wondering what i need to know before buying an engine off of craigslist. what to check for? what to test?
http://austin.craigslist.org/pts/4512710174.html
2_Liter_Turbo
Car: _________________
'96 S14 Coupe: SR20VET
'90 R32 TH1 GTR: RB26DETT
'92 S13 Fastback: SR20DET
'11 V36 Sedan: VQ25HR
'06 GMT800 2500HD: LBZ Duramax
Test the compression is important. Then use a small flashlight to look in the valve cover to check the cam lobes. Ask about the break in process (it was rebuilt). Take a peak at the spark plugs and inside the cylinders. Check for oil leaks around the head gasket, main seals, and the front cover. Check the oil pan to see if it's dented. Not too much else you can look at with it just sitting there.
