motoguy128 »
https://forums.nicoclub.com/motoguy128-u46857.html
Sat Mar 31, 2007 4:38 am
Be sure to use a reputable shop. THe adhesive used should take some tiem ot cure. The companies that slap a new windshield in 20 minutes and let you drive off, probably aren't doing it correctly. Having hte windshield mounted properly is important because the driver and passenger front airbags press against the windshield to control their deployment. IF the windshield is not replaced properly, the airboag will blow push out the windshield and you will not be protected properly.
I remember watching a segment about this on 60 minutes or some other news program.
