1998yellowstang »
https://forums.nicoclub.com/1998yellowstang-u251319.html
Wed Jun 17, 2015 11:10 am
Sorry, I didnt give you enough details on the picture. My new motor has two problems. The first is the cracked mounting ear that is on the far right side of the picture. I think the idler pulley mounts to it, so I am not really concerened about it.
However, the second issue is at the bottom of the picture. It is the mounting ear that is sheered off. That is where the oil sending unit screws into. Obviously, it has to be screwed in tight in order to prevent oil from coming out of it.
The motor is currently on a engine stand, so if I need to replace the upper oil pan, now would be the time. However, I would prefer not going that route unless I absolutely have to.
With the motor on a engine stand, is the replacement of the upper oil pan very difficult?
