pampadori wrote:where is your ecu pulling out timing? up top? down low? mine added 3-10 degrees downlow and pulled out about the same up top.
I don't know where it is actually pulling timing and how much, I just know that my car isn't making the HP it should for the mods that it has, and the blame has fallen to the ECU after countless hours of prodding, experimenting, etc. That's one reason I just bought a power FC, so I can actually look at timing and knock and ADJUST things, not send my ECU back to JWT so I can wait another 3 months for them to reprogram it.
Quote »I'm not an expert on ceramics coatings, but are you sure the crack goes all the way through? Stainless steel expands from heat more than cast iron or steel. It's always possible the coating only cracked[/quote]
It's cracked bad. Not only can you hear it and smell it from inside, but you can put your hand behind it at idle and puff puff puff puff goes the exhaust pulses. Oh, and for the ceramic coated, the SS will just turn blue and weird colors after 10 miles anyway :shocked2
