Pakaskas »
https://forums.nicoclub.com/pakaskas-u11698.html
Wed Dec 03, 2003 10:42 am
I have an 89 240SX KA24E. 130KI have a slow water leak into the oil.I took off the head and replaced the head gasket and had the head machined and tested. The old head gasket was in pretty good shape. While I had the head off I replace the timing chain, intake man gasket, exhaust gaskets, etc. The only bad gasket I would suspect was the intake manifold gasket, because I saw corrosion between the water inlet and the #1 cylinder intake port. At any rate, since I replaced that gasket, I thought it would solve the problem. I put everything back together and the car started fine. I ran it for a few days and I started losing water again and now I am starting to notice water in the oil. No noises and no external leakage. When I start the car, I have a lot of steam, not smoke, until it warms up. I would think if it was a cracked block, it would be leaking externally. I am suspecting maybe a cracked intake manifold? I think my first step will be to pull the timing chain cover off and make sure the inserts going to the block are sealed ok. But I am thinking of pulling the intake manifold first. Not sure how to test it. Any advice?
