Exar-Kun »
https://forums.nicoclub.com/exar-kun-u1725.html
Mon Aug 08, 2005 1:43 pm
well, seeing as you(if you had them set at 7) had stiffer shock settings on the rear, it would tend to voersteer if all else was held equal.
Now that you have effectively icnreased your suspensions effectiveness in the front, it may be even more pronounced.
I would definately reccomend getting an LSD for the rear, weather it be VLSD, clutch, helical or hypoid, get one. YOu'd be suprised how much of a change that mod alone does to the car.
Check your air pressures all around also, differences as little as 2psi can modify the way a car feels, esspecially at or near the limit. Be sure to check these cold (like when you wake up).
After making sure tha's all set, set your shocks to 2F 4R and adjust from there.
Also, make sure it's not your driving stlye making the car 'oversteer' steady state over or understeer is relaly only caused by weight characterisitcs, weight transfer, and tire characteristics of a vehicle. More often than not, one person driving a car will think it understeer or oversteers due to their style of driving (braking too late/early, etc). Adjusting a car for a driver's style can be quite difficult, esspecially if you're prone to modifying how you drive.
-Chet
