-40* sleeves + 150ish* block + hydraulic press. Basically, simple tension holds them in.Orphan wrote:
EDIT: I also have no idea how they are held in place haha, I always get the picture in my head of them sliding down onto the crank haha. Can anyone explain how it all holds together?
I dont even see the liner in that pic, and I cant figure out what youre adding up. A 1mm overbore reduces thickness by 0.5mm.Orphan wrote:Hannibal are you sure about the liners only being 3mm? They look quite a bit thicker then that in this picture. Even so they don't look 2.5+3.175=5.675mm thick as would be a safe thickness to bore out 2.5mm radius.
