KEMP »
https://forums.nicoclub.com/kemp-u119247.html
Tue May 05, 2009 6:00 pm
if you saw the pistons, you would think different, its on one side of the piston, and its on the side the notch was taken out, they are off balnce enough for you to see when you hold the rod upside down the piston leans hard to the otherside.
the ring looked as if it may not have had enough gap, and went u and down in the top ring land, causing that side of the ringland to stretch.
i took it to another machince shop, they told me the signs were not of det, or lean conditions, it was on the side, not the top, and they, just by looking at them, could tell the balance issue caused it.
it was dragging on the cylinder wall on one side(side of notch)
that sid of the ringland(one side only, on every piston) looked like this > from the side instead of the otherside whic was [
the symbols are not reresenting scale, just showing what they looked like.
even the machine shop that did it, said it wouldnt happen from either balancing(which i think is BS) nor the lean condition. they think there wasnt enough gap in the ring so it closed up and touched eachother causing the ring to max out and stretch the ringland by dragging the ring.
either way, i know it was they're fault, but how can they not take resposibility for it, even when they said its the ring gap, that THEY gapped.
they are trying to say they can't do anything....
