Courtesy window not going up again after disconnecting batt.
Home of the Nissan Cube forum and CubeDriver.com
Zero2Endless
Car: 2002 VW GTI 337 (Sold) 2009 Pearl White Cube 1.8S 6MT
Hey does anyone know a trick or anything to get the coutesy window to go up by itself again? I disconnected the battery to install sports horns. And after I connected it after the install...the window wouldn't go up by itself. Should I just take it to the dealer again? Sad faces.
chompsticks
Car: ???? Nissan Cube Krom
No need to take a trip to the dealer.
1. Put your key in the the aux mode.
2. Open the window all the way
3. Close the window and hold the button up for 5 seconds or more after the window has closed
4. Release
5. Confirm
ChopsQube
Car: 2010 Nissan Cube 1.8
Yep, the procedure chompsticks listed above works like a charm. Not only do you have to do this after disconnecting the battery, but also if you pull the door panel off which involves disconnecting the plugs on the back of the switches.
Zero2Endless
chompsticks wrote:No need to take a trip to the dealer.
4. Release
5. Confirm
Sweet!!! Thanks!!!
And it really works!!! Yeeeeahhhhh. Now I just gotta get the dealer to give me a bolt and grill clip that they lost when they had to re-apply my timing belt! Ahhhh
Return to “Cube Forum”
