db_autotek »
https://forums.nicoclub.com/db-autotek-u63360.html
Sat Jul 20, 2013 4:27 pm
Got it sorted out, here's my actions in case someone else runs acrross this problem some day. First, the easy one, the rear door. After removing the door panel, I found a loose connection at the door (LAN) control box and a loose connection at the plug to the door lamp housing socket. Quick fix and now that light works, still no action in the front door courtesy light.
So I studied the FSM for many hours, with the front door apart. Here's the important knowledge: the + wire ito the courtesy lamp is purple with a red stripe, as noted in the FSM and noted in person. This wire is always hot, I found out with my multimeter. This makes sense of course. So I have +12 at the hot wire, so now I know that wire and anything before it is good.
Testing the black ground wire for the lamp, I had no continuity between it and ground with the doors open. I tried it with the door(s) open, and while manually operating the door switch, no effect and no change. So now I know that the ground wire from the lamp to the inside of the car is damaged.
It could not be have been shorted, otherwise the other lamps would either fail to work or be on constantly. It must have been pinched off somewhere.
So now I was faced with a choice, do I continue tearing the car up and pulling out wiring harnesses until I found the break? Or, do I run a new negative wire from the footwell lamp? I went with option B, and since I had the door apart already, it was quite easy to run a wire through the harness sheathing so it doesn't look ghetto rigged. I ran it down by the ac motor to the plug of the footwell lamp and spliced it in with a butt connector. In the door, it was easy to follow the harness and make use of existing points to keep the wire tucked securely.
So there it is... The source and resolution of months of mystery haha.
