Where are the “flood plugs” in the floorboard? I’m not familiar with it honestly so I’m not too sure of what you are speaking of.VStar650CL wrote: ↑Sun Jan 30, 2022 8:43 amThe plastic "flood plugs" in the floorboard will be the simplest way to route wires inside without needing to drill. Poke some holes in them and then seal with hard RTV or body sealer once everything works. Even long strings of 5050 LED's will only draw a couple of amps, so powering two strings off the dome circuit shouldn't overload anything. The biggest issue is sealing the strings, I recommend a couple coats of clear Flex Seal and lay it on thick.
Oh, okay. I'll check that out then.VStar650CL wrote: ↑Sun Jan 30, 2022 9:28 amThey're plastic plugs in the floor of the car that are often used to let water out when a car floods. Almost all vehicles have them. On Nissans they're generally covered with seam sealer on the inside but are pretty obvious when looking from underneath.
Yes sir, found one right above the spare tire under the vehicle going into the trunk.VStar650CL wrote: ↑Sun Jan 30, 2022 10:16 amYep, the old Pathies had separate front and rear floor panels so I expect you'll find plugs at both ends.
So I installed the lights and they work as should when opening and closing doors.VStar650CL wrote: ↑Thu Feb 03, 2022 9:19 amNot that we get any sub-zero conditions here in Arkansas, but I did want to make sure the strips on the Altie were going to stay where I put them. To that end I used a dab of "gray death" Permatex Ultra Gray RTV at the ends of the strings and about every 6" or so along the length in order to augment the self-stick. I then covered the strips with green masking tape for a couple days to let the adhesives set up. Only after they were good and stuck did I peel the tape and hit them with Flex Seal to complete the installation.
I did have a problem one time with the trunk switch assembly. I believe it’s built into the lock, but a while back when opening the trunk the dome lights would not come on. I sprayed some wd40 in it and fiddled with the latch and it never gave problems again.VStar650CL wrote: ↑Sat Feb 05, 2022 12:19 pmThere's no control of the lamps on a '97 by the SEC, they're all wired straight to the door switches so there's no possibility of "leaky" silicon parts causing anything to light. However, LED's can be sensitive to small amounts of ground current that aren't sufficient to light up an incandescent bulb. My guess is one of your door switches or lamp fixtures is wet or corroded and supplying a few hundred ohms of "leakage ground" to the circuit even when all the doors are closed. You should be able to track it down by disconnecting the door switches and fixtures one by one and see which one is providing the leak.
No, not with a circuit that's purely ground-switched. Putting incandescents back in might "pull down" the leak and make it invisible, but that's not exactly a fix, just a coverup.
Alright, if it occurs again I'll check that trunk switch. I had issues with it before so that should be my first suspicion.VStar650CL wrote: ↑Sat Feb 05, 2022 1:48 pmNo, not with a circuit that's purely ground-switched. Putting incandescents back in might "pull down" the leak and make it invisible, but that's not exactly a fix, just a coverup.
So they’re Nilight led pods, 3 on each side. The 3 on one side plug into each other with the last light having a positive and negative that go into the cabin. Same with other side.VStar650CL wrote: ↑Sun Feb 06, 2022 9:18 amDepends how you have them wired and what the relative voltage drops are for your dome LED's and the underglow LED's. If they're parallel to the domes (wired across both the same supply and ground circuits) and the drops are equal then you're right, the domes should glow too. However, the drops may not be equal. Single LED peanut bulbs generally have drops around 2V, strings are generally 6~8V. Could be something about your source wiring too, if it isn't parallel. Exactly what wires are you tapped into, and at what location?
No it doesn’t come on with the key off. Sorry, may have explained that part wrong. When the lights are glowing and I turn the key on, the dash light glows as well even if doors are closed.VStar650CL wrote: ↑Sun Feb 06, 2022 10:51 amThe door indicator coming on is the key, because if you look at EL-96 and EL-99, the bulb in the cluster shouldn't have any power with the key off and there's a blocking diode that should prevent it from forming a parasitic ground through the ignition circuits when the key is off. For that bulb to light with the key off, the blocking diode has to be leaking. I don't know how difficult it is to get at your cluster, but I'd suggest pulling the door lamp bulb if it's accessible and see if the problem stops. If so, the blocking diode in the cluster is faulty and you can fix it by wiring a second diode externally onto the R/B wire at the back of the cluster. Something like a 1N5401 (3A, 100V) off eBay should do the trick.
Yeah I understand, will have to check which ones are leaking the ground.VStar650CL wrote: ↑Sun Feb 06, 2022 11:19 amIf it's only with the key off then you definitely have a leak to ground someplace in the system on the R/B wire. The diode on EL-80 can't really cause a problem, that's to prevent parasitic grounding of the luggage lamp through the spot lamps when the front dome is in the door position and a spot is switched on. So when the spots are off it shouldn't really affect anything. I think you're going to have to disconnect your switches one by one and see if any of them makes the problem go away. It's possible you have a chafed wire on a ride that old, too. LED's need so little current that even a couple hundred ohms can light them up, a dead short isn't necessary.
