I recently picked up an 89 240, had to replace the wiring harness on it b/c it was fried. Getting to the rear of the car, the stock 89 fuel pump plug has a Blue/Red wire, Yellow/Blue wire, White/Black wire, Yellow wire, and Black wire. The harness I believe may have come out of an 90 240 and the fuel pump section has no plug, but the wire colors are Black/Yellow (w/ gray dashes), Red/Black, Green/Blue, Black w/ gray dashes. Just wondering if anyone knew which wire would go to which.
Also, on the passanger side engine fuse box. Does anyone have a picture of the fuses themselves, or the fuse box cover. there are no fuses or fusible links in the box and I need to know which one goes where and my cover is yet to be found....junk yard was no help either.
Thanks a lot all.
