MojoMan wrote:quote from nissan_s14:Since you have everything out already, I would change out the pilot bushing (from SE-R), the rear main seal (from SE-R), the clutch, and the throwout bearing (from s14). Regrease the input shaft (dont get any on the clutch) when you reassemble it.
The throw out bearing and clutch from s14 would not be correct. The 89 maxima clutch would be correct or you call and get one from act or whoever like robbbby. Its a good thing that robbbby has the correct ones or you (nissan_s14) would have wasted his time on your poor lack of knowledge. The grease you use is a high temp lithium grease with molybdenum disulphide. It should tell you in any FSM for clutches and trannys what to use. Now unless you meant s14 silvia and he has an s14 silvia that would be a different story. But you weren't.
Mojo: Poor lack of knowledge? Please read my original post again and the quote you used from my post...NO WHERE DID I SAY YOU USE THE CLUTCH FROM A S14. This is what I wrote: ...rear main seal (from SE-R), the clutch, and the throwout bearing (from s14). NOTE THAT I DID NOT PUT ANYTHING IN QUOTATIONS AFTER CLUTCH, LIKE I DID FOR THE REAR MAIN SEAL, THROWOUT BEARING, AND PILOT BUSHING. Logically, one would deduce that since I put parentheses in everything else, that maybe, just maybe, I purposely left out the parentheses after the word "clutch". Anyone with a basic command of the English language probably knows how to correctly read, use, and understand parentheses.Oh, and the correct throwout bearing to use is IN FACT, from s14..a 1995 s14 with KA24DE to be exact. You can verify this info by doing a simple search on freshalloy.com , zilvia.net, or srswap.com (under the FAQ section).It is obvious that you are the-quick-to-pass-judgement type. That, and you are a MORON.
Robby: For the rear main seal you want to get it from a 91-93 B13 Sentra SE-R.
