couple questions
jerzy_illest_pa
Car: 300zx N/A
hmm for some odd reason my low beam lights dont work it automatically turns on the high beams i think its a problem with the pod that controls the light and for some odd reason my back lights dont turn on when my light are on any suggestion but they do work when you step on break
Milo (San Antonio)
Car: Project LOWFATZ (weight reduced slicktop TT)
Sounds like a combination of 2 problems. The high beam concern is probably due to the light switch on the steering column that allows you to switch to and from high to low. The rear light problem may be due to a burnt out bulb or a possible relay. I would check the bulbs in the rear taillights first.
jerzy_illest_pa
Car: 300zx N/A
but when i step on the brakes all bulbs light up none are out or anythingthat y im confused i checked the fuses n all good im lost
cmeasley
Car: 92 300zx na 2+2 (sold) 97 maxima GLE (DD)1990 300zx TT!!!!!!!
the same exact thing happened to me. its a blown fuse. i got pulled over and got a fix-it-ticket for it and i didnt even know the tail lights were out. but ya its a fuse in the box under the dash next to the clutch peddal. also check and see if the lights work on your speedometer and all that stuff.
jerzy_illest_pa
Car: 300zx N/A
k ill check all my switches and fuses cause I just finish swappin my interior n I was doing my cluster n that's when I notice those little things does any 1 have the diagram for the fuse box by the clutch petal so I can kno which fuse thankss guys
nghtrain88
Car: 1991 Nissan 300ZXTT
http://www.machzracing.com/450...r.jpg
if that doesnt work.. go to about page 8.. the thread titled low/high beams created by me and the link is down the bottom posted by mtcookson
jerzy_illest_pa
Car: 300zx N/A
can some 1 help lol ive checked fuses n everything now i have no clue wats wrong or wat i should try next 2 fix the problem n this sucks cause i need 2 pass inspection n i can cause of i have no low beams n i have no back light only when i brake they turn on
SpeedFreak_Josh
Car: 1990 300zx TT
Your brake lights and your parking lights might be the same bulb, but they have different filaments in that bulb that light up. That is why you can have one working and not the other. If your switch is bad for your headlights causing it to light up the high beams, it could also have something to do with your parking light circuit. Try 2 things. 1:put in a new bulb in the rear tails and check.2:check the headlight switch. (do your front parking lights currently work?)
nghtrain88
btw, a headlight/turn signal combo switch is about a $230 part from Nissan dealer.. I just replaced mine from them b/c I had a hard time finding it elsewhere online
jerzy_illest_pa
Car: 300zx N/A
so I was messin wit the car again n I also notice that I have a connector in the back unpluged n I have no clue were it goes n also my cluster does not lght up
