Couple questions regarding electrical items....
RyanY
Car: 2006 Nissan Quest Special Edition
Hello there, Just picked up a 2006 Quest S Special Edition today. We like it alot.
One item I am having trouble with is the backup sensor. The button has the off light on and it will not turn off (meaning it is in "off" full time). Anyone have suggestions?
Also, when you roll the driver's side window all the way up it then immediately opens by 1/4. The only way to get it to stay up is to hold the switch in the up position for 5 - 10 seconds after the window is all the way up. (update) Just realized the passenger side does this too....?
fixer
Car: 08 Sentra
the limit switch has to be adjusted on both window motors, just remove the door panel and there is a small black button on the window motor. raise window all the way up, push in the button and lower the window all the way down, and release the button. then ck operation of windows. about the rear sonar-if the light is on all the time that means it probably doesnt work. and will have to be tested. if you are not familiar with the tesdt procedure its best to take it to the dealer
