SilverShadow »
https://forums.nicoclub.com/silvershadow-u7058.html
Wed Apr 11, 2007 12:13 am
1. There is a detent in the switch, you need to pull the switch all the way up, if that is not the problem you can try this:
If the windows do not close automatically
If the power window automatic function (closing only) does not operate properly, perform the following procedure to initialize the power window system.1. Push the ignition switch to the ON position.2. Open the window more than halfway by operating the power windowswitch.3. Pull the power window switch and hold it to close the window, and thenhold the switch more than 3 seconds after the window is closed completely.4. Release the power window switch. Operate the window by the automaticfunction to confirm the initialization is complete.5. Perform steps 2 through 4 above for other windows.If the power window automatic function does not operate properly after performing the procedure above, have your vehicle checked by an INFINITI dealer.
2. I believe that it is only there to assist in closing.
3. If you go to the Comfort and Convenience settings you can select Lift Steering Wheel on Exit and Slide Driver Seat Back on Exit to be either on or off.
Not trying to be a wise *** but I would spend some time reading you owners manual. There is a ton of information in the book.
