Couple questions about the J
NismoJ30
Car: 1994 Acura Integra
1992 Nissan 300ZX TT
ok, i am on my 2nd 93 J30. my first one was in in good condition and it needed no work. i am just looking for some more maintenance tips.the fuel filter and air filter is done. i read the DIY thread and based on the information i am going to use the NGK double platinum. any thing else recommended? i checked out my TB's, my MAF. i don believe there is much more but enlighten me if there is. Also is there a way for me to get a sunroof motor from anybody here. i really don want to go to the dealer. Last thing is, i wanted to test if my LSD was stilll good so i put the car in neutral and i dropped it into drive and it fished tailed way left. i just need a little imput on that because in my other j30 when i did burnouts the car went stright. thanks
gr8scott72
Car: 1994 Infiniti J30t
NismoJ30 wrote:ok, i am on my 2nd 93 J30. my first one was in in good condition and it needed no work. i am just looking for some more maintenance tips.the fuel filter and air filter is done. i read the DIY thread and based on the information i am going to use the NGK double platinum. any thing else recommended? i checked out my TB's, my MAF. i don believe there is much more but enlighten me if there is. Also is there a way for me to get a sunroof motor from anybody here. i really don want to go to the dealer. Last thing is, i wanted to test if my LSD was stilll good so i put the car in neutral and i dropped it into drive and it fished tailed way left. i just need a little imput on that because in my other j30 when i did burnouts the car went stright. thanks
Change transmission fluid/filter
Change rear diff fluid
Seafoam in intake
Turkey baster power steering fluid out, replace with new. Repeat till clean looking
Bleed brakes/check pads
Replace timing belt if needed
Replace drive belts if needed
Flush radiator/cooling system
That's a list of a few more for you to do!
NismoJ30
thank you! but i thought changing transmission fluid on a automatic meant bad news?
brandonjustice93J30
Car: 1993 Infiniti J30
only if you have the shop that did Elisha's do yours....lol
gr8scott72
NismoJ30 wrote:thank you! but i thought changing transmission fluid on a automatic meant bad news?
Well, the fluid isn't going to last forever.
Just pull the plug, let it drain, drop the pan, remove old filter, install new filter, clean old gasket off pan, clean magnet, install pan with new gasket, measure fluid you drained out of transmission, add that much new fluid back in, take short drive, check level.
NismoJ30
thank you i guess it's worth the try. does anybody have a response to the question about my LSD?
