Couple Questions About SR Vacuum Lines
2_Liter_Turbo
Car: _________________
'96 S14 Coupe: SR20VET
'90 R32 TH1 GTR: RB26DETT
'92 S13 Fastback: SR20DET
'11 V36 Sedan: VQ25HR
'06 GMT800 2500HD: LBZ Duramax
Ok, the info I have is from Heavy Throttle. I am finishing up my swap, and have a couple questions. This first pic I'm pretty sure of what to do except when it comes to what the FPR line tees off to:
This is what I believe to be the "boost control solenoid". Am I correct? Also, where do the various lines go to????? This one is the main one I am having problems with:
This pic, I think the nipple on the cold pipe is supposed to go to the boost control solenoid, but I am unsure. Will someone please clarify this for me:
Thanks for any help, I am trying to get the swap finished by tonite, lol.
Silvia007
Car: 93 Nissan 240SX SE Fastback
Bottom Pic nipple on left goes to boost controller then to wastegate. Nipple on the right, I just plugged up. I don't have stock plumbing but that's how I hooked up my lines. I'd consult the FSM, there's plenty available online.
SpeedRacer1
Car: 1990 240SX, G35
2_Liter_Turbo
Pimp, thanks.
2_Liter_Turbo
Also, why is there 2 vacuum ports on the Greddy BOV? Which one do I hook up to the TB?
Silvia007
Ahh.. this is where people fail to see the greatness of the Type S. The first nipple goes to a vac line where as the small nipple goes to the hot pipe or cold pipe. What it does is supply the bottom side of the diaphram with boost. When you let off the gas, there's vacuum on pulling on the diaphram from up top, boost pushing diaphram from bottom = twice the speed that the valve moves at. I know this increase the response of the valve, but I think it's to assist if you want to run a much more higher spring tension.
2_Liter_Turbo
That makes sense. Sweet. So should I just tee it off the line on the cold pipe that goes to the wastegate actuator (which is already tee'd)? Or run it's own line?
