DrifterXRPS13 »
https://forums.nicoclub.com/drifterxrps13-u10091.html
Mon Dec 27, 2004 7:35 am
well for starters i have an 89 hatch, 5 sp, with 150xxx miles. the problems that i'm having seem to be coming from the cold weathe perhaps, not sure,
1. my ebrake light stays on, when i'm driving even though the ebrake is down. it never used to do that until it starated getting cold
2. my lap belt light stays on even when my lap belt is buckled...same as above.
3. the most annoying and frustarting problem that i present you with now is everytime i slow down or brake, it sounds like there's a bathtub of water swishing around the trunk area, i know there's no water back there i checked in the trunk, under the spare, even in the rear fenders, you wouldn't believe the **** i found in there from the previous owners.
it's as if you took a fish tank, filled it with water about 3/4 of the way and then moved it away from you and then bring it back real quick, if that makes any sense at all!
help please?!
