180fan »
https://forums.nicoclub.com/180fan-u3602.html
Sun Apr 04, 2004 9:03 pm
If you want the polyurethane bushings, I went with whiteline. Those work well. If you want some of the metal tension rods, those get pretty expensive. I can get the Tein tension rods for 190 but I decided I'd rather spend less and go with the polyurethane since I was low on cash and needed the part anyway. However, now I'm looking for cusco tension rods but those cost $$$. So it's up to you as to how far you're going to go with your suspension. Many don't want the harshness associated with the metal pillowballs of the Tein, Cusco, JIC, or etc but want something better than the stock leaking bushings and go with the polyurethane ones.
