Postby
sil820 »
https://forums.nicoclub.com/sil820-u13559.htmlWed Jun 16, 2004 9:53 pm
1.does any1 know what alternator i can use with my car?.. can i just use any alternator?? 2.what thermostat can i upgrade to?? i need a new one.3.I have an oil pan leak...wher can i get taht gasket? 300z? work?4.any place i can take my lsd?? i have just need 2 install it.. how hard would it b if i did it myself and used like a jack or sumthing 2 lift it in place??5. neeed a dyno tune soon.. any recomendations?
Postby
SeVa-S13 »
https://forums.nicoclub.com/seva-s13-u4555.htmlWed Jun 16, 2004 9:53 pm
If you have an RB20, the alternator from a KA24E will work. You just need to lengthen the whole in the slider bracket thing a little bit. I suck at explaining things online, but if you get you, it will mount right up and you'll see what ya need to do.
Postby
goofynick6 »
https://forums.nicoclub.com/goofynick6-u13220.htmlWed Jun 16, 2004 9:53 pm
I can swap a vlsd in about 30 mins now, it's pretty easy. Just unbolt everything with the car up on jackstands, and then lower it out with a jack..then reverse.
Just so you know, you'll need an 18 and maybe 19mm socket for the rear nuts.
