couple of rear diff. questions
patrickm1587
Car: 1990 240sx- SR20 swap and a turbo that's absolutely too big, spools around 4,400 and I love it!!!
Alright. I finally picked up a '95 j30 diff from a local junkyard today that has 140k miles on it. First question: how can I be 100% sure its an LSD? It doesn't have a sticker on it anymore. A guy told me one way to tell is if you spin the input shaft the output shafts should both turn the same way and they do. Is that right? Second question: do they make any upgraded bushings/mounts I can use? I don't want solid mounts or anything but I know they need to be replaced and I'd like to put something decent on there. And I read somewhere that I will need to get longer bolts to go in the front of the diff, is this correct?
pella
Car: 1995 240sx S14
Just did this two weeks ago. i beleive all the J30 diffs are VLSD.i used all the same hardware that came off my 240 just put in the diff, and presto ten bolts later its in.
terry_240sx
Car: '93 240sx hatch
try spinning one output shaft, they should both spin the same way.
you can also try hand turning both of them opposite directions, which should be tough to do but possible.
I decided to just stick with the stock ones, and i think they're just fine.
You don't need longer bolts if i remember right, but if you don't get the bushings you'll need a huge washer to compensate for the bigger hole.
hope this helps :)
