couple of questions
es sex0727
Car: 1991 piggy???
okay, here are said questions. One, if i buy the type x tail lights it says that all is included except the wiring. But i should already have the wiring if i have functioning tail lights? Two. I am thinking of ways to make my little red rocket a tad quicker. could i in theory put a cower stage two cam into a pretty much stock engine without doing any damage or anything.
Drakelee
Car: 1992 Nissan 240sx RB20det
1986 Mazda RX7:for sale
1997 Ford Ranger:PitTruck<3
you have a SOHC?
es sex0727
Car: 1991 piggy???
dohc sorry i didnt specify.
nifares240
Car: 1993 240sx Black-Project Car, 1993 240sx Red-SOLD, 1994 Sentra, 2004 Nissan Sentra SE-R SPEC V-Daily, 1999 Toyota Camry
you're going to need a tune to take fully advantage of the cams. I don't know if those cams you listed can be used with OEM valve springs.
about the tail lights, I believe you just slap them on and use the wiring harness with the bulb respectively from the car.
Drakelee
the stage twos are plug and play, I just got a set. only hassel is cutting the exhaust cam and the 100mile or so break in period, the valves click until it all settles in.
nifares240
that's the reason I went with the s1 cams. I didn't like the idea of grinding off a perfectly made cam.
Drakelee
how are they working out
nifares240
s1 cams are great especially paired up with a tune from JWT.
